finally going to lower my truck tonight
Lil Ram
south texas
I have been waiting but I went ahead and pulled the trigger bought me a 2/4 drop. I have 20" stock rims and tires can I cut down to a 3/5-6 safelt
delunad
I'm sure you can without problems
Lil Ram
Lil Ram
south texas
I just read the 1/2 off the front and 1.5 off the back. Do u know if I need to trim bump stops tho
BlkRamRt
SoCal
HEMI 5.7
yes you will need shorter bumpstops.
Lil Ram
Lil Ram
south texas
I will post before and after pics hope all goes well
C3ntury
2009 Ram 1500 CC Sport
If you stick with the 2/4 drop instead of cutting further, can you preease do me a favor and measure the front and back bottom fender to ground...if time allows :)
Lil Ram
Lil Ram
south texas
No I put the stripes...I use to have factory pinstripe painted along the sides but I removed them and put these on
Are those factory stripes on your truck in orange?
Ya for sure if I do just put the 2/4 I will get the measurement for u
Lil Ram
Lil Ram
south texas
Lmao my bad swap the posts around for the correct one hahah wasn't paying attention
Lil Ram
Lil Ram
south texas
I dropped my truck to a 3/5.5 after all and dam I'm glad I did it looks sick. And best of all "I have no wobble or rubbing what so ever"
C3ntury
Nice stance. You end up cutting the 2/4?
DERJ
Austin
2014 R/T
Looking sharp!
Did you use the Belltech and cut it?
mattmid101
2010 2wd
5.7l
How does it ride? Would you be worried about towing anything?
Lil Ram
Lil Ram
south texas
The ride is good not bottom out or rubbing and I really don't tow anything but will try and see. And ya I bought the beltech kit 2/4 and cut it used the factory shocks but I will end up putting drop shocks later
And this morning I hit 110-115 on the way to work and no wobble at all and pretty good ride
C3ntury
I'm assuming that's what, about 10-11" from ground to bottom fenders( not guard)? Good to hear you have no "wobble-wobble."
Twizzy228
Illinois
The lower you go, the better chance of eliminating the wobble.
Well done sir!
Lil Ram
Lil Ram
south texas
Thanks and I will get measurements for y'all when I get a chance on a leveled surface but my rear is up I say about 1/2 more than the front. I will most likely level it later by cutting about 1/4-1/2 a coil turn more. But I have stock 33" tires and I will also b putiing about 29"-30" tires to bring it a bit lower
mvm2
