Finally got level installed.
MBADEN
Canton ga
Finally got around to installing the supreme Suspension 2.5 level kit. Wanted to post pics for those considering it.
Front passenger/drivers- 36.75/37 inches from ground to top center of fender.
After passenger/drivers- 39.5/39.75.
Also finally got rid of the stock rubber and went with 275/65/20 Nitto Terra Grappler G2. Great tire so farm took about a 2-3 mpg hit all around but expect that to level out a little after the tires wear in a little
kurek
Northwest
Did you correct your speedometer/ECU for the new tire size? Your wallet will thank you :)
M
MBADEN
Canton ga
I have not. I didn't think the tiny change would matter much..only an inch difference diameter. @kurek
Tyler Baxley
Fayetteville
Where did you find your 2.5 inch leveling kit? I can’t find any for 2wd 1500s. Only for 4wds.
