Finally put Bilsteins in after 3 trucks
JLEONARD
Massachusetts
5.7L
Finally put 5100s on my 18 Ram 1500. I went the cheaper route in the past and put Ranchos in past Trucks. Never saw a positive change other than changing out worn shocks.
With the Bilsteins, yes they are stiffer but a heavy, sloppy Ram needs stiffer. This thing rides like it should. Only put them at 1.4 leaving me 1" of rake (I tow). Thank you to everyone on the forum for touting these things. I finally listened and it was a huge upgrade in ride quality.
CanuckRam1313
Ontario Canada
2023 Warlock
They do a great job indeed. Congrats on the new upgrade.
I've got them in my 19' and immediately noticed an improvement in handling and cornering, especially on the highway on/off ramps.
Taylor513
Phoenix
I've had mine with 80K miles + and still love them
osprey ram
09 1500 4x4
4.7 lit.
I have 09 crew 4wd, 5100 on frt. set at 2.1 1in coil spacer in rear. 285/70-17 on stock wheels. Love the ride and handling.
s_wall98
Tennessee
I can’t decide between 2.1 or 1.4.
I’m stuck otherwise stock with stock 265s for a good bit so I’m thinking that 1.4 may be the route for me.
Do you have any before/after pics?
21SilverRam
Maryland
I’d like to see a pic also at 1.4 I will be getting them soon also.
Thanks,
Matt
mrack
Put a jack under your front crossmember and raise it 1.4”. Free and easy way to see exactly what it will look like on your truck.
