Finally went 6", anyone willing to lend a tire reprogrammer?
MadGumby
PA
Finally got the lift on, it is literally undriveable so it's at the alignment shop now. On the way over I realized just how off the shift points are and I'm only running 35's. Is anyone willing to lend me a programmer so I can get the points set? I'd rather save the $200 and get a decent tune in the future. Here's a little teaser, I'll update as I finish it up.
Krein
Red Lion, PA
Don't have a programmer but beautiful rig
bigred74
Illinois
1999 and 2017
5.9L Magnum and 5.7L hemi
Tuner generally only work on the truck it's programmed too and the cheaper $200 Speedo calibrators only work on one truck and then they are done
JB1
Houston, Texas
Congrats, you go with Zone or BDS?
As said the tire calibrators are married to the vehicle
M
MadGumby
PA
Ah you’re kidding me. I had no idea they were married to the rig for something like wheel size. Jeeps are completely different. Well I’ll guess I’ll have to add that to the shopping list then.
That is if they are able to get the thing aligned. I’m telling you, it was undriveable.
I went with the Zone and I’m really please with the way it turned out. Bils in all four corners
Reactions: JB1
M
MadGumby
PA
About 60mi north of Pittsburgh
MarshRam
2014 SLT 4x4, 2012 ST
Well, when you get your tumer, it will also do the recalibration for you. In the meantime, you'll be putting less miles on the EVIC vs. actual miles driven!
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Ok not close to me. I would offer to meet up and take you for a ride. You would buy a tuner on the spot. I had the opportunity to buy a used one to recalibrate the tires and turn off the MDS. Once I got it I loaded a canned tune and started reading what everyone was doing. I read 4 posts in a row that said I wish I would have ordered the hemifever tune earlier so I ordered the hemifever tune and agree with them 100%
You will not be disappointed. Your 2016 will need an unlocked PCM
https://www.hemifevertuning.com/category-s/98.htm
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
https://www.ramforum.com/threads/zone-6-lift-track-panhard-bar-re-location-bracket.126245/
Read this thread if you opted for the 5" rear coils the instructions zone provides do not mention anything about the top hole
M
MadGumby
PA
Thank you. I just got a call from the alignment shop. I guess the shop that installed it did something with the tie rod ends. I was driving and didn’t understand what he meant but he said he needs the factory ends because he thinks they replaced the uppers when they should have only replaced the lowers? Something about 4 degrees of toe out and he can’t adjust it as is. I’m, needless to say, not happy
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
The zone tie rod ends require the installer to cut off 5/8" off the inner tie rod
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
its possible they didn't cut the inner tie rod and installed the zone outer tie rod and whacked out your geometry. My zone lift aligned with no issues
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
@MadGumby
New tie rod ends will require the
trimming of the male tie rod end.
Thread the new tie rod ends completely
down once installed. Secure
the jam nut. 2016-2017 models
have may reuse the facotry jam nut
Remove the factory tie rod ends. Trim 5/8" from the end of the male thread on
the tie rod end. Clean up the cut edge with a flap wheel.
http://4x4media.info/instructions/zon/D2612.pdf
On page 16
M
MadGumby
PA
You guys are incredible. That was the issue. This shop figured that out just before I read this so they were on it. Now we’re back in business. Picking it up this evening.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
I highly recommend reading the instructions and doing a once over when you get your truck back just to make sure everything is where its supposed to be and bolts are tight. Being that the installer should snug bolts and torque when the truck is on the ground sometimes they get missed
M
MadGumby
PA
Yeah I am now going to go over everything. I had planned on checking bolts but now I’m definitely going to go through the instructions and also take a look at the rear relocation bracket you posted. I do appreciate all the input
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
No problem, your truck looks great
ram1500rsm
Trabuco Canyon, CA
What Jeeps ? Any programmer for JK's will be married to the JK vin number. With HPTuners it'll be $100 just to license your VIN, assuming the tuner doesn't have the unlimited licenses for your year model. I know for me to do your truck it'll be $100 just to license your truck to my VCM editor, from there i could change your tire size, your FAN settings and anything else in the PCM/TCM calbration i wanted.
