Firebird
- Jul 19, 2015
- 1,488
- 1,461
- 2019 Ram 2500
- Hemi
My first mod was a Pedal Commander
I laughed at this ^^^^when I was searching your posts for the grill change infoI just wrapped up my first mod the Dee Zee tailgate assist. Took bout 1 beer install time. Really comes handy if you use the tailgate often. NCRaineman you are right these trucks should have came standard with it from the jump.
Sent from my SM-G950U using Tapatalk
As for exhaust, I swapped out the stock muffler with a MagnaFlow 18". Left everything else OEM. I think it sounds good. It's got a growl under acceleration, but pretty calm going down the road... enough that the radio drowns it out.
Yeah Bils are easy and a nice improvement over stock. Set at 2.8 they will allow you to clear 35s just fine with the right offset wheels.
I also like many others ate running stock a upper a-arms with zero problems View attachment 135939
^^^^This is a great order of mods!
Personally I went with a 24" Magnaflow then a Catch Can but the CC should be #1
My first 2 mods in the first week: Amp Research Power Steps and a Gator tonneau cover. I really like the steps because they never take away the look of the truck and they go lower than a running board or nerf bar so it makes it easy to use.
Jeff,
TY for asking this!!! We just took delivery of a new to us ‘18, so I have been reading like crazy on things specific to these beasts!!!
And a HUGE TY to all who have replied!!!
Has anyone added the direct bolt in Magnaflow muffler only kit (~$380) to their truck? How does that sound?
How does the exhaust sound down the e-way while towing ~5k lbs? We will be towing our boat at times and don’t want any drone if possible.
Do you know the 18” part # by chance? Just cut the stock out, and added pipe if/as needed?
TY!
Do the stock 20x8s allow 35s without rubbing, or very minimal rubbing?
TY!
Same exhaust question: Any drone while driving down the e-way, and also any drone while towing ~5k lbs?
Do you know the 24” part # by chance? Just cut the stock out, and added pipe if/as needed?
Also, I just noticed your signature lists a rear spacer, and you have a set of airlift 1000 bags? Ever have any issues with both? I am considering the same basic set up , though maybe a larger rear spacer and the hd bags.
TY!
TY!
TY!
