Hello guys and girls
When it comes time for lifting or moving,securing a load,or blocking (jack stands)something that you will be working around or under BIGGER IS BETTER!!
Read capacities of the items you are using carefully,my rule of thumb is under the max capacity by 10-20% (safety margin)
There is NO substitute for safety!!
It only takes a split second for bad things to happen!!!
I have been lifting,moving,transporting heavy objects (as heavy as 46,000lbs) for 40 years with no incidents,knock on wood.
I am not a professional rigger,it has just been part of my life and business I was taught well,and learn new things all the time.
I would not want to read about some one being flattened while working on their truck!!
Regards
Don
