Not yet,but will soon! Hate the MDS when it activate, beer settings the gear manually to avoid the annoying MDS horrible sounds and vibrations.Did you purchase one of those gadgets? Interesting.
Thanks for sharing.
I was wondering if that was just for the first time or every time? I never had to do that on my Sierra. Since this is the test phase, I wonder if that's something that will get fixed.Sounds like a great idea, but a bit of a nuisance to use though. You can't just start the truck normally.
"To start, just deliberately turn the key on one “notch” at a time with a small (1 sec) delay between positions to allow the unit time to interface with the ECU."
-K
yeah, I just tried myself, lolIf it's just the first time then it wouldn't be a problem. Unfortunately you have to register with their site to see the full instructions.
-K
FWIW Ive read about issues with how the Pulsar "disables" MDS. Something about how it just revs the engine up to give it enough load to keep MDS off just by how the system normally works.
Not sure if the Range Tech device does something similar or not.
wouldn't be great if you could just pop a fuse out to disable MDS?
