for anyone who has installed cabin air filter...
Average_gatsby45
Cummins diesel.
how did you cut the hole out? (tools methods type of bourbon needed etc etc)
the videos i fine, tend to gloss over this important part of the installation.
17 ram 2500 laramie
Amos
I see you have a 2017. My 2017 came equipped with a door and filter from the factory. Have you already looked for it?
Brandon-w
Yukon
2015 Ram 1500
Used a soldering iron with the flat attachment. It sliced through nicely and clean. Blow Torch and an xacto would work nicely too.
Sent from my SM-G981W using Tapatalk
Dave2018
2018,Previous 1998
3.6L,Previous 5.9L
Yes, as Amos says, your 17 should already be cut out with the door.
This is the best installation video I've found. It is also true of later years.
Fast forward to 3:24 to start with the kit and installation instructions.
Average_gatsby45
Average_gatsby45
Cummins diesel.
wanted to say thank everyone for their help, and there was already a pre cut hole inside. i am rather amazed at how dirty that lil thing was
VelocityC6Z
Maryland
I have the door, just got it from amazon a couple days ago. Mines a 2016, already checked and I need to cut mine.
To be honest I'm stuck between the angels envy, woodford double oak and e.h. Taylor for Saturday's adventure... with a soldering iron, got a few different tips that should work.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
On my 2015 I cut mine out with a SHARP blade on a razor knife ! Some use a Dremel and maybe a oscillating tool would work !
OP Glad yours was already there ! Amazing how much crap it catch's !
Gary2
S Jersey
I just used a sheet rock knife. make light passes til its through . that way it looks nice and neat like a factory cut. I did my 14 and my 17 had one
Salty Ram
Hawaii
I want to add one to my '16 as there is only the "cut here" lines on mine and can see that the angle could be a PITA but do want a clean cut. Thought about the Dremel option but if you make slip - an oops won't fix it. So, thought too about the x-acto knife option. But, gotta get off the pot and order it so that it will at least be here to haunt me to get it installed. My wish-lists just keeps growing (like a good weed if there is such a thing). I'll figure it out when I dig in there fer sure!
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Just use the Sheet Rock' Razor knife and like mentioned make several scribes and slowly cut through it ! Yea pain in the butt but very doable ! A bright flash light will be a plus !
wallacemf
2500 4x4 Hemi 6.4
Strange, I had a 2016 2500 tradesman, and it came with the filter door installed, but no filter. They must have started including the filter door sometime in 2016, with some installed and some not.
senator49
Choctaw, Oklahoma
I have a 2011 and had to cut out the hole. I heated up a sharp knife with a torch and cut it out doing a little bit at a time. Everything came out OK.
gixxer
SK Canada
4.7L
dremel tool or a really sharp utility knife and heat.
MRFREEZE57
pacific northwest
my 2016 had the removable cover, just had to install the filter. your 17 likely already has the cover.
Salty Ram
Hawaii
So, I ordered the air filter kit yesterday and looks like it will be here on the 30th. I should be commenting on the install next weekend. Additionally, my 6" BDS Coil-Over kit finally came in this week and my wheels and tires should be here on the 27th so it may be a very busy weekend!
chri5k
USA
Diesel
Had to cut my 2016 2500. Used a box cutter and heated the blade with a torch.
KLook
Harrison, Tenn
When you cut it out, what do you use for a cover? 2014 Tradesman here.
ChloeBrooks
