Found a fix that worked for a 2017 1500 display screen, 8.4
Dave M S
Illinois
My 2017 1500 Laramie had an issue I found out that can be common for 8.4 screens. The screen was jumping from SiriusXM to media player all on its own, very randomly and very annoying. Googled that issue and found out it is somewhat common, I tried the reset suggestion, holding the mute button and tuning dial in until the screen went blank and then booted itself back up, but that didn't solve my dilemma. What did work for me was to disconnect the positive lead on the battery and wait a couple of hours, when I hooked it back up and started the engine it did a completely different type of reboot and so far, fingers crossed the display has been working like it use to. The dealer suggests replacing the head/radio unit and the cost for this if the dealer does it is around $1500.00 I know some people are having issues with the display delaminating itself, mine hasnt done that.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
The ghost touches and delamination are one and the same issue. The battery disconnect you did only appears to have corrected the issue because the electronics were allowed to cool. The problem's symptoms come in stages 1 Radio gets hot, 2 ghost touches occur and 3 overheating causes screen delamination. The issue can be "fixed" by keeping the radio cool only during the the early stages before delamination. I added active cooling to mine and replaced the thermal sync material inside the radio with a higher quality thermal pad. It sounds like yours is in a correctable state and it may be wise (if you like the factory setup) to due some preventive maintenance (attached images of fans). You may be able to get away with fans or thermal material and not both, but I did both and also made a heat shield for the screen from motorcycle fiberglass exhaust wrap sealed with reflective foil tape too...2 years with a formerly ghost touching screen without further ghost inputs (except for once when the fan fuse blew).
To test, drive around on a hot summer day with your heat on full. Ghost touches should start again under these conditions relatively quickly.
He ghost touches and delamination are one and the same issue. The battery disconnect you did only appears to have corrected the issue because the electronics were allowed to cool. The problem's symptoms come in stages 1 Radio gets hot, 2 ghost touches occur and 3 overheating causes screen delamination. The issue can be "fixed" by keeping the radio cool only during the the early stages before delamination. I added active cooling to mine and replaced the thermal sync material inside the radio with a higher quality thermal pad. It sounds like yours is in a correctable state and it may be wise (if you like the factory setup) to due some preventive maintenance (attached images of fans). You may be able to get away with fans or thermal material and not both, but I did both and also made a heat shield for the screen from motorcycle fiberglass exhaust wrap sealed with reflective foil tape too...2 years with a formerly ghost touching screen without further ghost inputs (except for once when the fan fuse blew).
Thank you for that idea SKB,i copied your idea awhile ago on my wifes 2019 Challenger,and it's made quiet a differance in how the radio works on a hot day
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Yeah, I forgot to mention it performs better when cooled too (at least it feels more responsive/snappy). I'm thinking about tinkering with my wife's new UConnect 5 because it feels super laggy. I think separating the screen from the radio module was a direct result of the delamination issues on the older 1 piece units.
Atcer2018
Virginia
Just saw this post. Great idea, thank you. I’ll be doing this project over the winter.
Atcer2018
Virginia
Can I pick your brain? Where did you draw the power for the fans? Simple 12V DC fans? Fans blowing or sucking? What did you use to mount the fans? Thank you
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
1. Tapped the cigarette lighter plug
2. Arctic F9 Silent, 92 mm 3-Pin Fan... https://www.amazon.com/dp/B0119SG8X4?ref=ppx_pop_mob_ap_share
3. Sucking away from radio blowing toward engine.
4. Zip ties
I also replaced the factory thermal material with this...
Details here:
Post in thread 'How To: Install a 2018 4C (UAQ/UAS) Radio in 2013 - 2017 RAM' https://www.ramforum.com/threads/ho...as-radio-in-2013-2017-ram.116140/post-2484546
Mido
Kuwait
Dodge charger
V6
4. Zip ties
Details here:
Thank you so much
