Fox 2.0 and 35's?
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
So I've been doing some reading and it seems like the 2015 sport black 20" wheels are 18mm offset so if I were to get a zero offset my wheels would technically be pushed out -18mm from where they stand now? This offset **** is confusing
Take a look at the Guide to Leveling & Wheel and Tire Sizing linked in my signature. I explain how offset works in there and there's a few pictures that may help you.
But yes, essentially you have it correct. The stock 20x9's are +19 offset so a 9" wide wheel with a 0 offset will stick out 19mm more than the stock setup. 19mm = 3/4". The conversion is 1=25.4mm
M
Mviohl311
Thanks for all the help guys, I think the end result will be icon coilovers set at 2.5 with a 315/70r17 trail grappler so it measures 34.6 and I'll be just under 35 and a 0 to -12 offset depending on how far the bushwacker extend a flares come out.... will also be adding the add stealth front bumper, stay tuned
M
Mviohl311
Brandonjansen I read that thread and thank u that was very informative, ur a smart dude I appreciate the help
quietpeen
2021 TRX
Hellcat
busherwacker flares extend out far...for that reason i would go with the -12mm 17x9 wheels
M
Mviohl311
Quietpeen bushwacker pocket flares extend about 2.6" but the bushwacker extend-a-flares only stick out 1.7"
quietpeen
2021 TRX
Hellcat
Oh ok
I know...read more post less lol
M
Mviohl311
lol quietpeen, again thanks for all the info I'm getting a build sheet together now and hopefully it'll be done by summer
