front disc brake clicks at low speed
zeustheram
North Caroolina
5.9 360 V8
I just had brake work done 2 days ago. I never heard any noises or anything before i had my brake pads replaced. Well i go get them changed now my driver side front break is clicking really loud at low speeds 5-10mph. The rotor has a bad grove cut into it now as well. Could it be the rotors bent? or the caliper or what?
jwheeler
Washington
Where is the groove cut in the caliper? That could be the problem. What is rubbing on the caliper?
Ramunit
Stating the obvious take it back to the man who did the brake job and have them do it right. Other than that, pull off a front tire and caliper and see what's running on that roter, it's a fairly simple job. I had some clicking noise from my left front once and the lug nuts we're not torque down right, everything was fine after I torqued it so check those too.
Z
zeustheram
North Caroolina
5.9 360 V8
UPDATE: calipers have to be replaced along with lines and my front driver side hub is falling completely apart. so on the hunt for a new hub.
UPDATE #2: Ordered the new hub should be in within the week. sadly trucks gotta sit at home till it comes in.
