Front emblem removal
*tim*
I've read some and it says its just held on by clips but it won't come off seems like there is adhesive of some kind holding it on
mocaby73
illinois
The emblem on my 2012 has clips holding it on. You push the top and two sides through lift it out the bottom just slides in.
Darkflow
Odessa, TX
I just removed mine and there is no adhesive holding it on. It's just clips, push the top and bottom clips out. Then pull on the emblem a little, i used a knife to help lift the emblem up on eachside a little more to get a better grip on it and began pulling slightly and it finally popped off.
Its a 2 piece emblem, the black back piece and the chrome emblem. The chrome emblem slides in place and clips onto the black piece. If you mess with it a little bit the chrome piece should pop off the black piece.
T
*tim*
Finally got it off. There was a small strip of double sided tape. Just took some gentle prying
