Front power windows
Jdthomas625
Cleveland, North Carolina
I’m having a issue where the only two switches working on my drivers door window switch panel are the rear windows. No other button on there works nor do the lights light up on the side view mirror selectors. If I go to the passenger side the switch works just fine. I’ve checked for broken or loose wires throughout the harness from the plug at the cab all the way to the switch’s. I’ve replace the black door module box behind the door panel aswell as the switch panel. Please any help or a point in the right direction on what I need to do
stevenram
Army
Midwest
Have you pulled the door panel off to check connections at the switches? I’m not much help on electrical issues
Jdthomas625
Jdthomas625
Yea I have. I’ve even went as far as taking the switches apart to make sure there wasn’t corrosion or anything else in the way. I would like a wiring diagram but I can seem to find one on it even using the search feature on here.
RamCares
n/a
n/a
Hi Jdthomas625,
I regret to hear of the trouble you are experiencing with your truck. If you are not able to determine a solution based on suggestions provided here, and you decide to address this with your dealer, we are more than happy to provide you with an additional layer of support for that process.
Mark
RamCares
Nealsrow
Ontario Scarborough
I am having a issue with my front windows. i have replaced the wiring harness the module and the switch. any help would be great. Neal
