Fuel gauge calibration?
raxxter
Colorado
Last weekend I replaced the fuel pump/level unit in my 05 3500. I had to fill it for the first time this morning and now the fuel gauge only reads ¾ full. It’s always been fairly accurate up until now. I tried resetting the gauges by holding the odometer/trip button in while turning the ignition to on and letting the cluster go through the reset cycle. The gauge still reads ¾ full.
Is there some other way to calibrate/reset the gauge, or should I take back the pump unit? It’s an aftermarket (Precision brand) unit.
The truck’s a 5.7L Hemi, 2WD, 4DR, DRW, with the 35 gallon tank.
Thanks!
HemiLonestar
Navy Badge Coast Guard
MD
Sounds like you either got a bad one or it might be setup for one of the different size tanks (26 & 34 were also available that year).
Dean2
Near Edmonton
If you have AlphaOBD you can reset it but, if this is actually the correct pump and float for that tank it should be reading correctly. I would be inclined to get a replacement pump.
raxxter
raxxter
Colorado
Thanks, everyone.
Sounds like I’m better off getting another pump.
I did specify I had the 35 gallon tank, maybe I was given the wrong one.
HemiLonestar
MD
Not in this case, 2005 is PCI bus; AOBD isn't compatible.
Thanks, everyone.
Possible, especially if it was a parts chain store.
Dean2
Near Edmonton
Thanks, everyone.
Check your parts numbers, the 34 and 35 gallon pumps are not the same.
Precision Fuel Pump Module Assembly - A30466
Part #: A30466 Line: PFP
Fits 2005 Ram 3500
$238.99 Each
Fuel Pump Module Assembly With 34 Gallon Tank
This product has restrictions regarding its warranty
Terminal Type: Blade
Connector Gender: Female
Connector Shape: Oval
Precision Fuel Pump Module Assembly - A30467
Part #: A30467 Line: PFP
Fits 2005 Ram 3500 $182.99 Each
Deliver by Tue, May 23
FREE Next Day Eligible
Fuel Pump Module Assembly With 35 Gallon Tank
raxxter
raxxter
Colorado
I'll double check the numbers when I get home, but price-wise, I got the correct 35 gallon tank unit.
If it is the correct one, from what I understand, the fuel gauge should read correctly. So, I'll exchange it for a different unit, it that's the case.
HemiLonestar
MD
You are dead on. AOBD only goes back to 2006.:waytogo:
Not exactly. AOBD is CAN bus compatible only. So yes, that is 2006 in trucks. For the LX platform (in this case Magnum/300), that is very early 2005 MY. Considering the sheer volume and variety of platforms and years it is compatible with (as far back as 1992 with some Alfa Romeos) I tend to stick with what is CAN and not CAN overall.
Dean2
Near Edmonton
I did not know Can Bus technology went that far back, but then again, after growing up in Europe, I wouldn't own an Alpha Romeo product on a bet. They were the rough equivalent and rank right up there with Russian made cars like Lada and British Leyland/Austin Morris products for lousy reliability.
HemiLonestar
MD
You ain't lying. Every Alfa I've had the misfortune to encounter was an electrical nightmare. Made my uncle's TR4 so much more appealing (and Triumph's, like many British roadsters, were known for electrical issues).
Marshall
Sk, Canada
2014 sport
It could be the float rod is bent, if you bent it down ,maybe would fix it, but then how much is a 1/4 of a stroke and would E still be correct
Would still have to take it out.
If you still have the old one ,compare the resistance on the coil with a good meter to see if they read the same with float up and down. If the reading when at top, them the gauge will be off.
Dean2
Near Edmonton
So Op, was it the correct fuel pump and defective or the one for the other tank?
BuschLatte420
chill water by day, drink beer by night
WNY
2022 classic tradesmen crew cab 6’4 box
5.7L NON E-TORQUE 3.92 gears 4x4
noraa73
