torinreality
- Jun 30, 2016
- 10
- 2
- 2016 Ram Rebel
- Supercharged 6.4
I'm building a new motor for my 2016 Rebel, a 392 stroker with a ProCharger that I'm intending on running at about 12 pounds. So I need to upgrade my fuel system, and I'm hoping for some advice from folks who have done this before.
Right now I'm leaning towards an Aeromotive A1000 system, because I like the idea of an external pump (in case I have to change/repair hardware), and the A1000 should be big enough for my needs (and I don't mind the noise). My intention is to install bulkhead lines for the supply and return lines (AN10 and AN6 or 8), and use the Aeromotive pickup filter (part #18002) inside the tank for the supply line.
My questions for the gurus out there:
1) I'd rather run the 100 micron filter external to the tank, but I'm thinking I need some kind of diffuser in the tank to prevent suction vortexes. Are there better options for the in-take supply line?
2) Should the inlet port pull from inside the basket or outside? Do I have to worry about eductor/replenishing jet-pump issues? Am I forced to keep 1/4 tank of gas or so to prevent sucking air?
3) Are there any complications with abandoning the stock pump but keeping the fuel gauge working?
4) Am I over-thinking this, because there's a simple solution while using the stock basket and hat?
Any information or personal experiences would be greatly appreciated. I couldn't find the information I'm looking for with the on-site search or Google.
Thanks!
Thanks!
