Fuse Box wire question
NY Andrew
VA
5.7L V8 Hemi
Any suggestions to run wires out of fuse box? Ideally wouldn’t want to cut or drill but not sure there’s any way around from it. Plan to do piggy back fuse tap for camera.
clifford15
RI
CTD
Depending on how big or how many wires there is a slot near the + cable attachment stud. I have my 12GA seat heater wire exiting through there.
NY Andrew
NY Andrew
VA
5.7L V8 Hemi
Seen that when I just checked. You just wrapped it around the plastic? Doesn’t pinch or crush it too bad?
NY Andrew
NY Andrew
VA
5.7L V8 Hemi
Beautiful, thanks! Gonna do that and ground to neg battery terminal I think. Can’t remember where I last bonded my previous mod if there was a ground bolt.
madtrucker2016
New York-Staten Island
3.0 Hurricane twin Turbo
I did what your looking to do . In the back lip of the fuse box I drilled a small hole just so the two wires could fit. also after that put some atv sealer on the wires at the hole. looks clean and you really cant see the wire. covered the wires in a plastic jacket for wires to look good and neat .
NY Andrew
NY Andrew
VA
5.7L V8 Hemi
I actually ended up drilling DOWN on that area you guys slipped the wire through because I didn’t like how it was pinched weaving through the grooves so drilled it down and then threw a rubber grommet on top to protect from fuse box closure. Of course if anyone’s in there the potential is to pinch the wire, but decided not to drill a whole that way they can’t say I really modified it, it’s just recessed a bit hah. I used ATV sealant for the firewall entry.
