Fuse location
ocmd
Maryland
Help. I blew the charging port on my dashboard, the old "cigarette lighter" type port. Should not have put a portable inflator in there! The owners manual is useless as to what fuse this is. I located the fuse box next to the battery and popped it open. Too many fuses to determine which one powers that charging port. It is a 2019 Ram Big Horn1500 hemi 4wd. Any ideas of where to look are appreciated. This is a work truck and I need to keep my phone charged! Thanks.
turkeybird56
Central Texas
Hemi 5.7, Non E Torque
YES, second under dash, under steering wheel. U have to remove 2 screws from cover under the steering wheel, I think 8mm, but not sure on side. That is where PDC is inside truck. I am not sure on what fuse number was qouted, not looked that us, look in yer manual, it lists both fuse boxes
turkeybird56
Central Texas
Out of MY 19 manual
Cavity Cartridge Fuse Micro Fuse Description
F48A 10 Amp Red – Rear View Mirror / Humidity Rain And
Light Sensor (HRLS) / SW Window
Passenger / Rear USB / Wireless Charging
Pad Mod
F49 – 15 Amp Blue Mod CVPM / SNSR Blind Spot / HDLP
Adaptive Front Lighting Sensor (AFLS)
F50A – 10 Amp Red Battery PACK Control Mod
F51 A&B – – Spare
F52 20 Amp Blue – Direct Battery Feed
F53 – 15 Amp Blue Mod ICS Switch / Mod HVAC CTRL /
Sw Bank Upper / Sw EPB /
Mod Control Steering
F54B – 20 Amp Yellow Power Outlet Center Seat
F55 25 Amp White – Upfitter
F56 30 Amp Pink – Mod Network Interface
F57 20 Amp Blue – Direct Battery Feed
F58 20 Amp Blue – Direct Battery Feed
F60 50 Amp Red – Mod Inverter
F61 – – Spare
O
ocmd
Maryland
@turkeybird56 I saw that and still dont know which fuse it is. It isnt the "power outlet center seat" as I dont have an outlet there, any ideas are appreciated and I guesss I can grab a spare if the amperage is the same? Thanks
turkeybird56
Central Texas
IF there is a fuse in F54B, do not go by description, check that one.
That fuse probably also has 2 positions: one for Power on all the time/one for key only. It will be the only one that has 3 prongs in one fuse place. I am 99% positive that is the fuse for the circuit U R concerned about
LOOK in this thread post #10 also:
