Fuse Location ?
bereta1
Ky
2016 Ram 5.7 H. 8.4 radio. Which fuse controls the alternator ? Need to check if alternator is causing radio interference with the engine running. Radio plays perfect when I shut the engine off. Don’t have any LEDs.
Ken226
Washington State
B
bereta1
Ky
Mine has a dual fuse a 120a and a 180a. Do I disconnect the 120, 180, or both ?
Toon12
Ontario Canada
Pentastar 3.6L V6
A fuse won't make radio noise or interference.
There are two common strategies that can be used to suppress Radio Frequency Interference (RFI) and Electro-Magnetic Interference (EMI) radio noise. The first suppression strategy involves preventing the production of RFI and EMI electromagnetic signals at their sources. The second suppression strategy involves preventing the reception of RFI and EMI electromagnetic signals by the audio system components.
The use of braided ground straps in key locations is part of the RFI and EMI prevention strategy. These ground straps ensure adequate ground paths, particularly for high current components such as many of those found in the starting, charging, ignition, engine control and transmission control systems. An insufficient ground path for any of these high current components may result in radio noise caused by induced voltages created as the high current seeks alternative ground paths through components or circuits intended for use by, or in close proximity to the audio system components or circuits.
Check the ground strap from the engine to the body is in place clean and secure.
Preventing the reception of RFI and EMI is accomplished by ensuring that the audio system components are correctly installed in the vehicle. Loose, corroded or improperly soldered wire harness connections, improperly routed wiring and inadequate audio system component grounding can all contribute to the reception of RFI and EMI. A properly grounded antenna body and radio chassis, as well as a shielded antenna coaxial cable with clean and tight connections will each help reduce the potential for reception of RFI and EMI.
B
bereta1
Ky
I understand that a fuse won’t cause it. Was just trying to eliminate the alternator as a source. With engine off, no interference. Thanks
