16Hemi
thanks for the good information. i will have to look into the insulation part of it first before i worry too much about heating it.
I’m looking to do another garage next year, did you plumb the system yourself?Good morning to all on the site!
I have a 30’X40’x12’ attached garage up in the Northern lower peninsula of Michigan. I installed hydronic heat tubing in the floor with 3” of foam under that. I used (4) 300ft. runs of 3/4” pex tubing in the floor. It keeps the room as warm as I want it. You want to make sure you use tubing with an oxygenated barrier for heat BUT NOT for potable water. I also used an antifreeze specifically designed for hydronic heating incase I lose power to our cabin.
Larry in East China Mi
