Kelly Arthur
The gas gauge on my 2019 Ram 1500 with 5.7 hemi will not read full, I can run the gas until it spills on thr ground and all it will read is 3/4 full
More than likely the fuel level sensor is the issue, they wear out and can can be replaced, it is attached to the pump, I’m pretty sure you can get the sensor separately.The gas gauge on my 2019 Ram 1500 with 5.7 hemi will not read full, I can run the gas until it spills on thr ground and all it will read is 3/4 full
