Gas mileage drop on 2500
muzupan
Rocky Mount NC
2019 Ram1500 Crew Cab
I just moved my stuff from Raymondville, TX to Rocky Mount, NC. Making the trip to the RGV my truck averaged 17mpg+ running 70 to 75 mph. On my trip back I pulled a 4x8 uhaul trailer and is was half full. I was surprised I dropped 3mpg to 14 mpg running 65mph. I was very surprised I lost that much fuel mileage with a small light trailer. I was expecting a 1 mile per gallon drop.
U&A
2016 3500 SRW
6.4 HEMI
I loose close to 2 mpg with a bed FULL of wood. Definitely around 4,000lbs. Id be happy with 3 mpg lose with an enclosed trailer.
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
I would get down on my knees and beg for 3 mpg loss towing. I’m getting 14.1 MPG empty, that’s hand calculated.
U&A
2016 3500 SRW
6.4 HEMI
Stock tires?
U&A
2016 3500 SRW
6.4 HEMI
Yes sir, bone stock.
With my 285/75/18 toyo mt’s and 4:88 gears i will get around 14 empty on the highway if it isnt to hilly. But as soon as there is minor hills it goes down to 12.
Joy360
I was surprised that I got 17.5 mpg / 420 miles before my low fuel light came on. I filled up and it took over 24 gallons to fill a 31 gallon tank.
2018 2500 HD 6.7 Hemi cc 7.3 gears
jaflowers
6.4 hemi
What is a 6.7 hemi and what are 7.3 gears? Be an interesting setup for going very SLOW.
mtofell
1mpg drop is not realistic for what you describe (did you base this on something other than a WAG?). 3mpg sounds totally reasonable for towing that trailer vs. not. Lots of other factors too. Wind alone can make close to a 3mpg difference if you're driving into it one way and it's at your back the other. (this would only be 1.5 mpg change each direction) I recently hauled an empty auto trailer that probably weighed 1500# with just about zero wind resistance and it reduced my mpg by +/- 2.
Administrator
Enclosed trailer? Probably due to wind resistance more so than weight.
^^^ this
Wind drag makes a bigger impact on milage than the weight.
I've seen 16 mpg towing an empty 24' enclosed car hauler (3K lbs) and just a hair under 15 mpg with a 28' enclosed weighing in at 8K lbs when the wind is calm with my EcoD. When the wind picks up significantly, I've seen the mileage drop off to 12-13 mpg.
Joy360
6.4 Hemi and 3.7 gears. I screwed that all up last night
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
I average 12 empty around town/backroads, 17 highway empty or so and somewhere around 9 mpg towing my TT.
slim chance
lancaster, pa
hemi 5.7 eTorque
just got a new 2500 Big Horn ... look at my fuelly for that trk below ... running thru the mtns of central Pa
Marine Les
Show Low az
5.9 cummins/3.6 Pentastar
I pulled an Airstream TT weighing 5500 with a quad in the bed and got 16mpg. When I put a tall cabover weighing 2500 on I got 13mpg without a trailer behind. Air resistance is the mpg killer king not weight and going slow (55) helps a lot but can create a problem for the flow of traffic.
