Gauge Cluster Upgrade.
Archaic2021
I have a 2012 crew cab ST model with the basic Gauge cluster.
I have read before than I can get a sport cluster and it be plug and play.
Is this true?
apepe0738
Peoria, Arizona
2012 Ram 2500 Crew Cab 4x4
Yes it is true, just be sure to get one out of a 09-12 truck, the 13+ won't work. I would personally go with one out of a 11-12 truck because the 09-10 evic software is a tad different, but will still work. Also don't forget the steering wheel with the buttons. I am assuming you have the standard wheel without the buttons. Also look for one that has close if not the same mileage, unless you can find a dealer to change this for you. Hope this helps!
