Gauge cluster...
lenstar65
Delaware city,Delaware
3.9l
My truck is 99ram 1500..3.9l...it doesnt hav the tach in the cluster..can j plug a cluster from another 99 ram 2500 that has the tach?? Thank you..l
dapepper9
Iowa/Nebraska Border
5.9L V8
Possibly. You'll have to verify it has the same connections on the truck harness. I can't remember for sure but the no tach trucks may not have the wiring for it
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
If you don't have the stock hookup for the Tach, i'd look into the pillar mounted gauges, you can get aftermarket tachs for that as well as trans temp sensors (really helpfull).
C2ndLTpigeon
California
1999 Dodge Ram 1500 Sport
5.2L
I believe all trucks have the signal wire, all you need is the cluster and its plug and play. Millage will be incorrect as it is stored in the cluster. So ECU and Cluster millage will be different but shouldn't matter if you don't plan on selling it.
Yeret
Professional Procrastinator
Behind a computer saying, "looks easy enough..."
5.9 Magnum
I'm pretty sure that an a used or aftermarket cluster can be flashed to any mileage. So, if you've got 200,000 miles on your current cluster and you swap it with one that's sitting at say 180,000 miles, you can flash it to 200,000 miles. This is something that's going to have to be done a dealer though as they are the only ones that are going to have the tool to do so.
jlbayes
2001 & 1997
5.9l cummins
A used cluster cannot be flashed to change the mileage. The tach will work as it is a bussed message from the pcm to the cluster in 98-02.
Gr8bawana
6.7 CTD
I don't think this is true. What would keep people from changing the mileage on a vehicle for the purposes of selling it when it has a million miles on it? It is illegal to change the mileage on a vehicle. It is a federal violation.
https://www.justice.gov/civil/case/federal-odometer-tampering-statutes
jlbayes
2001 & 1997
5.9l cummins
It is illegal to change the mileage in a vehicle to lower with the intention of fraud. Changing the mileage in another replacement part to correct or reflect the true mileage is not illegal.
