Gear Indicator
Wadejesu
Alabama USA
Is there a way to display gear indicator on the dash with the 8 speed ? I know on a ford if you tap +/- on gear shifter it will display gear position.
turkeybird56
Central Texas
YES, in the Uconnect Display under settings, U go in and set it up to display. When I find out exactly where it is, I will come back in here and post. Not remember where in the menu's it is, lol.
NOTE: The Screen Setup feature can only be used while
the vehicle is in PARK.
Push and release the up or down arrow button until the
Screen Setup Menu Icon/Title is highlighted in the instrument
cluster display. Push and release the OK button to
enter the sub-menus and follow the prompts on the screen
as needed. The Screen Setup feature allows you to change
what information is displayed in the instrument cluster as
well as the location that information is displayed.
Screen Setup Driver Selectable Items
Upper Left
• None
• Compass (default setting – Premium)
• Outside Temp (default setting – Base)
• Time
• Range
• Average Fuel Economy
• Current Fuel Economy
• Trip A Distance
I skipped a few of the option menu's. In Owners manual starting on page 173...
Favorite Menus
• Speedometer
• Vehicle Info
• Driver Assist (show/hide) – If Equipped
• Fuel Economy (show/hide)
• Trip Info (show/hide)
• Stop/Start
• Trailer Tow (show/hide)
• Audio (show/hide)
• (Stored) Messages
• Screen Setup
Current Gear
• Off (Default) /// AS U CAN SEE OFF BY DEFAULT, TURN ON !!! ///
• On
Odometer
• No Decimal Point (Default)
• Decimal Point
Defaults
• Cancel
• Restore
RedneckHippy
Washington
2019 Ram 3500 Tradesman
6.4 Hemi w/ MDS
Mine says it right at the top center of the middle of the dash, switches from D to whatever gear when you hit the gear limiter buttons. Never had to mess with any settings.
mlrtimemach
US
2019 Ram Tradesman 4X4
Me neither
dbctmc
virginia
The gear limit buttons are the magic trick. Press the down one to enter gear limit mode and the current gear shows at the top center of the instrument panel. Then press the up button till 8 is underlined and you have the transmission fully automatic and the gear displayed AND you just turned off MDS, which some don't want to do but it's actually the main reason I do this every time I shift into drive. It should be a simple programming change (hint RAM) to allow this to be set as the default mode, but unfortunately, it's not.
RandomRam
On the Oregon Trail
It would be nice to have a separate MDS off button and be able to see the gear the truck is in. I leave MDS on when on the highway but shut it off in town.
Plainbroke
Kansas
Yes, that would be a nice feature.
Still wish I could have the gear showing all the time without loosing MDS on the Highway to see the gear. In town MDS is annoying.
Wadejesu
Wadejesu
Alabama USA
If you change default in the setup menu, will gear be displayed all the time, and MDS off or only way to turn it off is with gear +/- butons.
ThunderMug95
North Prince George, VA
A by-product of adding a tuner! Enjoying that feature. I still find myself running the gears to 8 lol. Old habits…
Gondul
Central Florida
That doesn't work (at least with the 2019 2500s) not sure if UConnect was 5 was changed to accommodate that function
Wadejesu
Wadejesu
Alabama USA
If you hit the tow/haul button, that will turn off MDS also, correct?
olyelr
Kewadin MI
Yes. And with my 6 speed, it also locks out 6th gear. Not sure if it locks out the upper gears of the 8 speed or not, but probably.
