gear install
2000ramhawaii
3.9 v6
started putiing in my gears today, disassembly went smoothly, everything is out, bearings been pressed onto the new pinion, i can't get the pinion tight enough, has too much play. do i need a bigger impact then a 650 ftlb to crush the crush sleeve?
has anyone out there made an adjuster tool for the carrier adjuster nuts?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Man bud wish I could help ya with this but havent personaly done a gear set yet.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
I haven't heard of any tools to adjust the nuts. As for the crush sleeve I would think that 650 ft lbs would be plenty but I may be wrong.
Here is some information from Richmond Gear. Not sure if they are going to be of any help.
Ring & Pinion Installation Instructions
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Sorry Man, Other than Tony, can't offer any real help either! I know I used a 3/4 Inch Power Bar will 4 foot pipe to get my Pinion Nut off in the driveway once doing the seal so there is alot of Torque there. Assuming your planning for this Job covered all the Tooling/Etc requirements then this should just be a minor Problem in the Procedure. Hopefully someone can chime in to get you the answer. Hope it works out smoothly, keep us posted.
2000ramhawaii
3.9 v6
as usual i'm in over my head :suicide:
the adjuster nuts are adjusted with a tool through the end of the axle tubes, i had seen somwhere that people were welding a large nut to a pipe to make a adjuster tool....
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Guess that would work. I never heard anyone having issues while installing gears. So kind of new territory.
2000ramhawaii
3.9 v6
the adjuster tool:
1.5" ball receiver nut (lightly ground down)
1" emt
3/4" socket
welded together:
2000ramhawaii
3.9 v6
ok............. evrything is in, set up, can't put on the effing c clips on the axle shafts. the ring gear is taller than the stock, so you can't drive out the cross pin shaft. what the EF!!
has anyone else put a 4.56 in a 9.25? anyone... anyone...?
i know i wasnt the only 9.25 in the group buy.
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
I'm not doing the gear install myself, so I'm no help, and I haven't heard of anyone else doing it themselves either yet.
