Sgt_Rattlehead
- Aug 6, 2017
- 28
- 3
- 2014
- Hemi 5.7
So i bought a used 2014 laramie 1500 with the 8 speed tranny I downloaded the build sheet from dodge/ram website and it says it came with 3.21 gears.... so here is my question, Ive been around quite a few muscle cars, before this truck it was a challenger, ever since i bought this truck i have been very impressed with the acceleration on this truck, it just doesnt feel like 3.21 gears, it really doesnt , so is there a stamp or something on the diff that will tell me for sure or any other way to find out???
fyi this is what it says on the build sheet:
3.21 Rear Axle Ratio
235MM REAR AXLE
Conventional Differential Rear Axle
235MM REAR AXLE
235MM axle is generally referred to as the later model 9.25 ZF diff,differant then the earlier 9.25,but seems to be a fairly decent diff,except for lack of good aftermarlet limited slip units.You can put a Tru Trac posi in them,but it's not cheap,as you need the earlier 9.25 gears and one extra pass side axle,plus the posi unit.The factory limited slip is the cheapest one you can put in,it'll hold up for most guys,but doesn't care much for horsepower and water box burnouts, if you're going to modify the truck,and run at the track fairly often.The clutches in the factory limited slip are usually the weak link
