TXKID
Ok everyone now bear with me on this... My understanding is that a lower gear ratio will get me off the line faster and vice versa with a higher gear ratio so my thinking led me to the theory that a lower gear ratio might help improve gas mileage in the city or at lower speeds (if you don't try and blow up your tires at every stop light) since its able to turn the wheels easier.... How reasonable is this?
And also if you have made the swap can you post your gas mileage before/after and what gears you have now and what you went from? Also if your currently running 3.92's with a lift can you post up your current mileage?
I'm currently trying to decide between the 3.92 or the 4.56 bc these current gears are just not cutting it, but I also don't want my gas mileage going down too much since its already horribly low and I make two hour round trips every couple weeks on top of my daily driving.
Any help would be greatly appreciated
