Get and alignment now or wait?
BigBlue05
Eads, Tennessee
Last night I replaced my upper control arms and tie rods and tie rod ends. I was going to replace the lower control arms as well but didn't have the right tool for the torsion bars. I don't know exactly when i will be able to get back in the shop to replace the lowers. But my truck needs and alignment bad. Should I get an aligment now or wait till I can do the lowers. And if I do get an aligment Will it need another when I do replace the lowers?
Ram Lover
Maine
5.9L 360
If your not sure how long it's gonna be I would probably get it aligned , your gonna wear the tires pretty bad depending how far out it is, and yes you'll probably need another one after, a lot of places do free alignment checks so have it checked out again after you get them changed before just throwing the money at an alignment you may not need.
Sent from my Z797C using Tapatalk
usaf2006
North Carolina
Or if you have a firestone auto center near you, they do lifetime alignments I've heard. So you could get one, put the lowers on and go get another for free.
bulrid8
Yep, firestone lifetime is the way to go.
Sent from my VS985 4G using Tapatalk
quietpeen
2021 TRX
Hellcat
Firestone will Do lifetime alignments but to a reasonable degreee. Maybe before you spend money on them explain your situation and see if they think it's reasonable from Their perspective
12sportmc
NC
Also dependent on how long you plan on keeping your truck. If your a trade it in every 3-5 yrs kinda guy might not be worth it. If you plan on sticking with your truck for the long haul then it's probably a worthwhile investment on the firestone thing
bulrid8
It is only $70 more. They will realign if parts are replaced due to wear.
dhows31
Mississippi
Alignment ASAP after suspension changes
