Gotta dumb question but.......
Budakane
Northern VA
345ci Hemi
SO, the wife tells me that the Killer Bee just hit 45K, and its bout time for a tune up. Honestly does it really matter which plugs I use? If so what are the recommendations? Thanks in advance. Airborne!
HemiBabe
DFW
I've always heard to just stick with the plain ol copper plugs they work best for our trucks
[tapatalkin]
S2kiHemi
Houston TX
Yes it matters what plugs you use. Hemis don't like the expensive platinum plugs. Get the plain copper plugs like Kristin said. Remember you need 16 of them.
txbass06
NE Texas
5.9 Magnum
Champion or NGK copper core plugs will probably be your best bet
WhiteRam
Dallas, TX
2012 2500 CCLB
6.7 CTD
Champion copper will do the trick just fine.
Remember to get 16 of them.
USMC1188
SW Ohio
None
Truckless...
Yep, like everyone else said, Champion Coppers
MADDOG
Living in a Firepit
Ditto...Champion Copper Core plugs will be the best for your truck - and mine for that matter!
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I have had great luck with the NGK 5306's. They are stock heat range, and have done well for me in the past. I also replaced my plug wires with the Taylor 8.2mm full length wires on my 03. You wont see any gains in performance, but the truck felt like it idled much smoother with the new plugs and wires.
HemiSport07
Central FL
I run brisk performance plugs in mine and my trick seems to like them got 10k on it since plugs
Budakane
Budakane
Northern VA
345ci Hemi
Thanks guys I'll tell my wife Champons it is!!!
hemi07yellow
Just did plugs and all the coils today. Wasn't that bad. Used champion #570's
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
A step colder would have you ready for your mods coming back home if you still go forced induction.
crcraft
