Guide to Leveling & Wheel and Tire Sizing for 06+ 4wd Ram 1500's
CUBS_WIN
I know the 13-14 Ram trucks have the not so thick ucas...my truck has 35k miles so i would say they are still in good shape...i just don't want ball joints popping...lol
Sent from my SAMSUNG-SM-G920A using Tapatalk
R.L.K.
Bristol , Tn.
If you go with the bils , even at +2.8" You should be fine , besides the uca ball joints don't just blow out , normally they slowly migrate upwards and is associated with a popping noise .
If this were to happen imo , if your driving normal or taking it easy you'd have time to order up a new uca whether it's a used low mile oem takeoff ( should be lots of those available ) Mevotecs or the SUPER BEEFY Zone one$ .
mr red beard
2014 1500 Tradesman Crew Cab 4WD
5.7L
Hey, I have a 2014 1500 tradesmen crew cab 4wd. I purchased Bilsteins 5100's and plan on doing the 2.75 leveling setting. the tires i purchased are 35X12.50-17 Road One Cavalry MT Tires 35 12.50 17 12.50R17 Mud Tire. everything i read in this thread states i should be fine so far. i just dont know what wheel specs i need. i wanted to do 17x10 but dont know what off set or back spacing i need. also will i need any spacers for the back tires?.
brandonjansen
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
You can run 17x10 wheels no problem. I'd recommend a -12 offset for your setup. You can run a -24 offset as well but that will require more trimming. The -12 offset may require a small amount of trimming as well.
DRkNESS
South Jersey
With my new wheels being 20x9 with a 25.4 offset and my Bilstein set at 2.1, can I go with a 285/60 as opposed to my current 275/60 ? These are the ines that I am looking at.52edd47060c91aa4e0cd44c5eefebb5b.jpg
DRKNESS falls
Kab
DRKNESS falls
I think you'll need a spacer, that positive offset is killer. I measured my stock tire to the upper control arm and got roughly an inch and that's with 20x8 at a +19 offset. This is exactly why I'm going with different wheels with a +15 offset
Kab
I've been using this site for trying to figure out the setup I want. Gives you a good idea where the extra measurements will be. http://www.willtheyfit.com
brandonjansen
brandonjansen
DRKNESS falls
Yes, you'll be able to run 285/60/20's on 20x9 +25 offset wheels. It's going to be very close, but they should fit.
You do know that the difference between a +19 offset and +15 offset is only 4mm (3/16") correct? That's not much more clearance if that's what you're looking for.
DRkNESS
South Jersey
I've decided to stick with 275/60 and go with either Toyo Open Country A/T or those new Continental A/T..
DRKNESS falls
Kab
I know it's only 4mm different from my stocks. I was looking at getting +25 22x10 wheels and really didn't want to fork out the cash for everything and then still have to buy spacers for almost 200$ I decided on a 24x9.5 with +15, shouldn't need spacers this way.
DRkNESS
South Jersey
^^^^. Oh DANG lol, I've only read about vehicles with wheels that size I've never seen one in person. Is it safe to say that you're 2wd ?
Kab
No I'm 4x4, with the wheel and tire setup I'll be almost identical to my stocks in height and should only be about 15mm closer to the Upper control arm. I don't think I'll need spacers here.
Kab
Also these are just summer wheels for me.
DRkNESS
South Jersey
Oh I see, well that makes more sense then. I only want one set of wheels so I'm playing the safe card and sticking with 20" wheels.
Kab
I just wanted to look a bit different is all. Everyone has lifted trucks with huge offset tires but not any around here have a sport look with big wheels and mildly aggressive low profile tires.
DRkNESS
South Jersey
I can't wait to see photos of those wheels without & with tires.
Kab
Kab
I'll have 295/45 tires. I'd like to get like 305/25's but I'm also trying to keep my speedo kinda accurate
DRkNESS
South Jersey
I've looked on Motorsports Tech website but I am not seeing 10mm spacers for my 2011 Ram BigHorn. Is it possible that it's the 1" spacer as listed here ?cf7d06a94bc126f8db42a8c8c8f9dadb.jpg
DRKNESS falls
Jus10case
