Nope stock bottom end. I guess I was closer to WOT than I thought because according to HP tuners I'm at 9.5 at 3/4 throttle and 11.2 at WOT. (This is at 85 degrees ambient temp)Holy Crap, I didn't read through the forum again, did you add forged pistons or anything or are you all stock on the top end? 10.8 at 3/4 is pretty high!
3.625 The pulley that came with it.What size pulley is on there? The 3.5?
Got tuned today. 511hp on 91 pump 578hp on e85. Listen to how quiet the supercharger is. Can barely tell it's got one.
492 ft lb at aprox 4700 rpm 91What kind of torque numbers did it put out and at roughly what rpm?
544 ft lb at aprox 4700 rpm e85
I don't know maybe next spring? I could take the vbox out of the evo and do a run with it and get a ball park number.When are you taking it to the track to see what it'll run?
Badass, looks like I’ll have something to do next summer.
Only familiar with twin-screw setups, how does the low end compare?
Do you have anymore info on your work with FCA? ETA etc?
Just waiting to get on the dyno!
Sent from my SM-N975U using Tapatalk
