Hanging up in park
blackhammer
diesel
I have a 2016 Ram 3500 and it has started to hang up in park. Even on level ground. I was at a gas station and I couldn't get it out of park. I was finally able to get it out of park by shutting the engine off. Put it to run and shift it to neutral. Restarted the engine and it would come out of park. Has any of you had this problem and if so what did you find.
RamCares
n/a
n/a
Hello blackhammer,
We're sorry to hear you're having trouble with your 3500. If you end up going into the dealer and need an additional layer of assistance, let me know. I am available via direct message and would be happy to help.
Jasmine
Ram Social Care Specialist
dwcw051910
Mississippi
I've just recently started having this problem with mine. 09 1500, and it's only intermittent. Did you find a solution to yours?
clifford15
RI
CTD
Wonder if there is a problem with the solenoid that was part of the recall. Mine was a little touchy this morning. Will need to watch for problems.
Musky Mike
NC
Becoming more common, if your in a safe place, video it and take it to the dealer and have send it to Ram.
https://www.ramforum.com/threads/transmission-won’t-shift-out-of-park.132201/
https://www.ramforum.com/threads/shifter-issue.132855/
https://www.ramforum.com/threads/intermittent-problem-with-rotary-shifter.46299/
