Hard start
jljbtm
Today when I started my truck it continued to crank and would not start I turn the key off and stopped the starter motor and then retry it again and it started like normal anyone had this problem mines at 2011 with about a hundred forty thousand miles
Sent from my SM-N950U using Tapatalk
RamCares
n/a
n/a
Hi jljbtm,
I certainly understand why this would be concerning. If this continues to occur and you end up addressing it with your dealer, please know that we are more than happy to provide you with an additional layer of support for that process. We're just a PM away.
Mark
RamCares
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
If you have a leak in your fuel system somewhere, the pressure bleeds off overnight and it won't be enough to fire the injectors until the fuel pump jacks it back up. Next time it sits overnight (or a few hours), try turning the key to ACC and listening for the fuel pump. Let the fuel pump run until it stops (which means the system is pressurized) and then try starting it. The first time you cranked it today, it may have not had enough pressure in the fuel system to fire the injectors. When you tried again, it may have had time to build up enough pressure.
jljbtm
jljbtm
Johnny I did figure it out turns out it is an old worn-out relay fuel pump relay and I simply used to jumper wire in the fuse box to fix it it might be a temporary fix but it's fine
JohnnyMac
Glad you got it figured out! Thanks for sharing the fix. Might help someone else down the road... :)
stevenmicheal
