Has anyone raised their battery tray
jedeisurf
Glendale AZ
Hi I am thinking about raising my battery tray because with a 4" drop in the front I am hitting the battery tray very often with my tires. Has anyone done this or a battery relocation?
Thanks David
12vrunner
Texas dfw
Man i was just about to post something similar. With my 2/4 drop both wheel well plastics are busted to crap due to those sneaky bumps. It doesnt look like i hit my tray yet. I may consider putting stock shocks up front instead of the belltechs.
jedeisurf
jedeisurf
Glendale AZ
When I was running a BT 2/4 I never had any problems with the stock 275/60/20 tires or my current 305/50/20 tires when I installed my Inez 4" drop in the front I was hitting all of the time, had to install a 1" spacer and still hit occasionally, I have busted out one inner fender mounts on the battery tray already. I think I can possibly raise the battery tray 2.5" if i make some new lower and upper brackets
and then I will be able to use a heat gun to stretch the plastic.
David
12vrunner
Texas dfw
I just got some rough roads around me and im always hauling butt lol.
Check out Charonblk's thread down in member trucks.Kurtis relocated his batteries
charonblk07
Calgary, Ab
F1-A forged 349ci
I had to remove the battery tray for various reasons but you'd have to run a different battery if you tried to raise the tray. I made some brackets for the ABS pump and I turned the fuse box 90 degrees with another set of brackets. With those supported the tray can be removed. My batteries are in the box but it can be mounted anywhere. I used 1/0 gauge welding wire to run from the battery to the alternator and to a distribution block that runs to the fuse box and the starter.
