Has anyone upgraded the factory inverter?
MuddyJeep810
I know, old post, but 150w inverters are a waste of dash space. I think it's more of a thing to awe customers that they have an electrical outlet in their truck, when in reality, 99.95% of items with an electrical plug on it won't work in said electrical outlet. Large inverters aren't even that expensive. It would have been fairly easy to make that a 1500w inverter that would handle at least 50% of things with an electrical plug on them.
ppine
Forester
Nevada
6.7 liter diesel
150 watts divided by 120 volts equals a puny 1.5 amps.
400 watts divided by 120 volts is still only 3.3 amps.
A typical electrical circuit in a house is 15 or 20 amps.
RamDiver
Marlborough, Ontario Canada
2021 DS
I'd be very concerned about the heat generated by a larger inverter, particularly if it were located in a confined space with no air flow on it.
What would be so terrible about trying to dissipate 1500 Watts of thermal energy from under the dash somewhere? :cool:
They could just mount a blower fan in the vicinity and it could double as a foot warmer, at least in the cooler climate regions. LOL
regal81455
Illinois
Couldn't see it being any worse than the 1500 watts worth of amplifiers stuffed behind my backseat lol!
PaleFlyer
Charlotte NC
I think the intent of the DASH inverter is to power a "normal" laptop. Most "normal" laptops are 90W or less on the charger. Tool chargers they probably expect if you want to use truck power for, you would have an inverter port in the bed. Which isn't a feature I think I have ever seen in a RAM, but I've seen a few taco's with it.
I also don't think I've seen too many people use them. Heck, the primary use for mine was a "better" USB charger (I lost my 30w+ 12v chargers at some point, and just used a spare wall-wart for a while, until I recently put in a 12V splitter block, which has 2 PD plugs.)
fast as I can get
Thank you for allowing me to join !
I have owned dodge and Ram trucks since the early 1980s.
I do have an electrical issue i would love to discuss tomorrow.
We have 2 Ram 4x4s one 2017,and a 2022
Hope to chat with you all soon.
ricky_bobby
Wake County, NC
6.7L Cummins
I am just glad I swapped to Limited seats which have better seat heat than my Sport vinyl/cloth buckets
It saves my wife from plugging her heating pad in the seat and saying "I need this because your seat heat stinks, but the outlet doesn't work all the time"
