Having Trouble Setting E-Fan Temps
vcode70
I know there has been a lot of talk on here lately about the e-fan mod, but I'm still having a little bit trouble. I have a '14 RCSB Hemi, and I recently installed the ATI Underdrive pulley and while I was at it, I removed the stock clutch fan. Since it's a '14, I was able to retain the stock AC fan, and I already installed the 180* t-stat. I know the fan is suppose to kick on at 195 and kick off 185, but for the life of me, I can't figure out how to set it with my Diablo InTune I-1000 DCX.
I got to the point where it says "Cooling Fans A/C Off" and "Cooling Fans AC On", but I'm not sure if this is were I'm suppose to change it, or if I need to go under the "Idle" menu, I just don't know. Any input would be greatly appreciated.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Change all fan speeds to 195-196 per Sean at Hemifever.
Paluby
Alaska
It's the high mph parameter that changes when The fan comes on. Top option for cooling and then again too option.
