Headed to the Dealership
Magdad
Gallatin Tn
I noticed a water line along the rear headliner the other day and it was soaking wet! The dealer is looking at it to determine next steps. I think I'll have them re-do the rear brakes that still make noise when backing up and have been replaced once and they can fix the driver side visor that's about to fall off! Oh, just at 15k miles too. Not happy.
chrisbh17
Third brake light leak? Or sunroof maybe, if the truck has one
Is this a 2019 new body style or a 2019 Classic?
whetrick1
Yeah mines in the dealership right now for a leak. They said 3rd brake light is leaking. This is the 2nd one they are putting in.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
you think after all the 4th gens having 3rd brake light issues, they would fix that on 5th gens....:(
chrisbh17
Thats why I asked if it was a classic or not. I would be very surprised (even for FCA) if the 5th gen third brake light is still a sieve.
2WDGranite
Cleveland, OH
Bummer! I replaced the 3rd brake light bulbs with LED's and everything looked watertight. I've seen the fix for rear brake noise and it's a clamp around the axle connected to the brake caliper via a bracket. I personally wouldn't want that set up but if your brakes are loud enough it may be the best option.
BlownGP
Houston/Baton Rouge
You mean to tell me the 3rd brake light still leaks????????????? hahah
whetrick1
That's what they said that they have been getting some bad ones in that leaked also. Me I don't think that they know where it's leaking at.
Graygoose
Oklahoma
Convert, for now.
small
Amen, like manifold bolts....for 10 years LOL
RamCares
n/a
n/a
Magdad & whetrick1,
We're sorry to hear that you have this concern with your Ram truck! Please send our team a private message if you are in need of additional support while in service.
Darlene
Ram Cares
whetrick1
Yeah they just txted me and said after installing new 3rd brake light it was still leaking. Now they're going to pull the headliner and see if they can see where it's leaking from lol. Hope they don't break anything while they're pulling all the plastic parts
Graygoose
Oklahoma
Convert, for now.
small
uuugggh, hate that for you....
AP3Photo
New York
My 2019 is at the dealership trying to figure out if its the third brake light or the satellite antenna. Needless to say, my headliner is a mess.
M
Magdad
Gallatin Tn
Parts are ordered and will be here next week. I asked the supervisor about the water stain in the headliner and he says oh if we have to replace that it's a big deal, we have to pull the windshield and re calibrate the mirror.... that's not my problem I told him! We will see how it turns out.
whetrick1
Tell them to pull it down enough to check the rear window frame. That's what they did with mine and found it.
demonram
As I backed out of my driveway a couple of weeks ago after a rain event, I saw water drip down from the headliner directly beneath where the high mount brake light is located. Had that happen once before and tightened the screws that hold it in and it stopped for a while. When it happened this time I ordered a light from eBay, with LED for about $24.00, plus free shipping. The gasket that came with it is a lot thicker than the one from the factory, and one other thing I noticed is that there are gaskets around the screws, might want to check them.
MMM
I bought this tstuff at Lowes: 10-ft Black Rubber Marine Automotive Weatherstrip
Item #: 161713 Model #: 01033
Good stuff to reseal the 3rd brake light.
The brake material on my rear outside left brake pad came right the backing plate off at highways speeds and I lost brakes. (~22k miles)
Doing so also trashed the rotor.
I had to replace brakes and rotors because of it.
I'd say there would have been over 1/2 material left and another 22k could have been driven if that didn't happen.
tomb
ontario canada
2012 bighorn-cherry red
Mine had a slow leak--took it off and the gasket wasnt seated properly-ok now.
Kmiko
