Header install question
hemi_hawk
I want to install obx headers, how do i prevent the manafold bolt from breaking and giving me the tick sound ??
nickpohlaandp
Lake Charles, LA
Stage 8 bolts are a gimmick. You don't need stage 8. All they are is a bolt with a PITA lock and circlip design that really does nothing if you understand thermal expansion. Any high quality bolt will do. I think the thread pitch is 8mmx1.5, but don't quote me.
As far as getting your existing manifold bolt out. Park your truck the night before your install. First thing in the morning douche the hardware with Aerokroil, PB Blaster, or some other high quality penetrating oil, and let it sit for 10-15 minutes. They should come out no problem.
PassivAggressor
If you already have a broken manifold bolt just drill a small hole into it and get an extractor to remove it. Mine came out pretty easy.
Sent from my VS990 using Tapatalk
nickpohlaandp
Lake Charles, LA
This is a viable solution, but please be careful. Extractors are made from hardened steel, so if you brake one off, you're pretty much screwed. I had to repair a few exhaust manifold bolt threads on my sons '94 Toyota. I didn't even bother with trying an extractor because I've screwed myself in the past. What I did was drilled the whole damn thing out (very carefully, mind you) and fixed the threads with an insert, one of those ones where you oversize tap the hole, thread in the new insert, and hit the 4 little prongs that stick out to smash them in and hold the insert in place. Worked like a champ. It was a bit never racking drilling into the head like that though.
charonblk07
Calgary, Ab
F1-A forged 349ci
Easy way to remove broken bolts, if you have a welder or a friend with a welder, just weld a nut onto the end of the broken bolt and it'll turn right out. The weld doesn't have to be pretty or even half-assed good, just enough to stick the nut to the bolt.
As for Stage 8 bolts, having put 3 sets of headers on my trucks and with a hell of a lot more heat in my exhaust than about 99% of hemi owners they are still in place, still tight, and haven't broken yet. The locking clip is nice but not required and I didn't have them on one set of headers for a long time and they never backed off.
john.dickey
Calgary, Alberta
My kooks came with stage 8 bolts so that was just a bonus. Like it says above, be generous with some quality penetrating oil, tap on the old bolts with a hammer to help the oil seap in the threads and they should come out with ease.
H
hemi_hawk
Well i have no broken bolts, just wanting to put new long tubes on and prevent a broken bolt issue in the future.
So would grade 8 bolts be ok ? Or what do you guys recommend?
nickpohlaandp
Lake Charles, LA
Grade 8 is plenty good. You'll need something that has a small socket size though. If you get a standard Grade 8 bolt from the hardware store it's probably going to be a 13mm or 14mm head size. You need something that's stepped down to around a 10mm like what comes with the JBA's. Why not just use the JBA supplied hardware? It is more than adequate.
H
hemi_hawk
Using obx headers
nickpohlaandp
Lake Charles, LA
Using obx headers
10-4. Personally I'd look into ARP, or use Stage 8's and don't mess with the clips unless you really want to. I used only ARP on my turbo engines I used to sell, but the were all standard thread, not metric. I'm sure ARP sells metric though. If they don't that's stupid. Everything is going metric nowadays.
StoneDude76
West Chester,PA
Not to hijack this thread but what goes into installing the OBX headers? Will I need to lift the engine?
Sent from my XT1080 using Tapatalk
nickpohlaandp
Lake Charles, LA
I don't see any reason to lift the engine for ANY header install in these trucks. There's room for days.
Lifting the engine makes it easier to get the retaining bolt out of the dipstick. I know a few guys have backed the bolt out as far as they could then cut it and a few people have cut the bracket itself,but the proper way is to lift the engine off the mount high enough to get the bolt past the motor mount.
nickpohlaandp
Lake Charles, LA
I've seen that about that bolt so many times on this forum and I just don't get it. I had no problem accessing the bolt whatsoever, even putting it back in after the header install was easy.
DILLIGAF
Canadian Forces
Canada
I just bent the tube and relocated it. no need to unbolt it. :)
nickpohlaandp
Lake Charles, LA
I removed my tube (kindof a PITA once you get the bolt out because you still have to fight the o-ring) and once I finished my install I just reinstalled it, feeding it between the #5 and #7 primaries. It was really pretty simple. The only modification I had to make was to the mounting whiz bang doohickey that used to bolt to the stock manifold bolt/stud thing. I used a pair of alternative lifestyle pliers and cut a slit out where the bolt hole was, loosened a valve cover bolt, and slid the mount in there. Works great, and I didn't have to alter the dipstick bends at all.
