atc06jh
- Feb 23, 2013
- 573
- 320
- Location
- Middle Georgia
- 2014
- Hemi 5.7L
So the wiring is confusing me. Tried to watch RetroShops YouTube and still don’t get it all. Can anyone tell me what plugs in where with the pictures below? Seems like I have to many wires.
That's a mess. No instructions?
B is your ballasts and ignitors.
Not sure about all the rest.
A- canbus adapters
B- HID ballast
C- projector headlight adapter harness
D- relay harness for the hid's.
If you have alfaobd you can eliminate A and D
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
I looked at the Alfa page. Seems like something else I’ll have to buy?
You should be able to adjust the lights same as factory without removing them. There is a hole in the top of the fender that the adjustment point is located. I cant remember what is needed, I believe it's a small hex head (maybe 7mm or so) and also the option to use a torx bit, but I cant confirm that. Just look in the little holes on top of the fender behind the headlight and you should see it.
They emailed back stating that it was normal since there was a temperature change. However, I never had this happen with the old lights. Stated since the headlight was warm and the cold water hit it, it caused fogging and will go away. But it was maybe 50 here and the water wasn’t much colder. So I’ll give it another wash or two and see what happens. At least I started a paper trail with the email and photos.Sorry for your fiasco, at this point I'd get my money back if possible.
