Headlight switch wonky?
TRANSMITTERGUY
Guys, my 2015 ram 1500's display says lights on when I turn off the truck and open the door to get out. I have to turn it to auto position to get it to stop alerting me, and the display to read normal. This just started happening a month ago. What do I have to buy now for it? A new headlight switch? I just replaced my gear selector switch 3 months ago. What a pain.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Leave it in auto, I haven't touch my headlight switch other than to turn fog light on. I was hopeful they would eliminate the switch, headlights should be on 100% of the time in my humble opinion. At least then you could see the people that can't drive as they are coming at you.
Silby
Glendive, Montana
I have the same problem.
Silby
Glendive, Montana
Mine won’t go on in the dark, unless I move it back and forth, and then sometimes it will shut off in the dark.
EdGs
FL
Headlight switch. Mine shat the bed a few years back, went very intermittent. Auto worked ok but normal on positions did not. Acted like a worn-out trace on the circuit board.
I think it was around $50 for a new switch module. Hopefully not too much more $$ now.
Was super-easy to change out.
Update: 68269910AA was $63 in Nov. of 2020. is $97 now at RockAuto. Only a 50%+ price increase, prices have gone stupid.
FYI, that part # is for models WITHOUT fog lights.
