Heat
mtnrider
Georgia
In the old days we'd use a water/air pressure (20psi max) technique to flush cooling systems. Even after a chemical treatment that method flushed out a lot of stuff sometimes.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 142099 miles.
That's what I use, works great...
Ramez
phoenix
Unless you plan on doing it again you'll flush back into the block too. That crud is in the block and needs to be blasted out. I ended up making a homemade flush gun and plenty more crud was pushed out the lower radiator hose. My '16 heat rocks now but time will tell.
Marshall
Sk, Canada
2014 sport
have you pulled your cabin air filter out and checked in there? you can also check that the doors are working. I have dual sone
I don't have a filter on my '14 but you should on the newer ones
Ramez
phoenix
Can't imagine why they don't mention flushing the block, since that is where all that crud is seems they enjoy doing this every year.
Rgesse
