Heated side view mirrors
Drayk
colorado
I've owned Rams for nearly 3 decades. My 2019 Big Horn (my 4th) came with power adjustable tow mirrors, but they're not heated. It's not something you really think about until you need them. Anyway, I can't get my dealer to commit either way to confirm if the wiring is there or not. I have a hard time believing Ram wouldn't pre-wired for them.
Anybody have thoughts on this or know what it would take to add heated, and possibly folding tow mirrors?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I would have to think that IF your OEM TOW Mirrors have all the normal tilt motors for the mirrors glass & signal light & courtesy light to see your Footing, called Puddle Lights
That the truck would be wired for heat,
At Least to the Door Module
The Door Module is behind the Inside Door Panel
I do not have a image of the Tow Mirrors.
This is the image of regular mirrors
notice the notation of
Pins for Heated Mirrors
Those wires, in fact all of the wires in the image, come directly from the door module
D
Drayk
colorado
Thanks so much, man!! So, if I Yank the mirror out of the assembly & see those 2 little wires/plugs, I'm wired for headed mirrors? I'll just need to get heated tow mirrors & possibly a software update?
GTyankee
3.0 ecodiesel
I don't know if it is that simple.
The side mirrors, no matter which ones, regular or Tow , heated or non heated, comes with its own wiring Harness.
That wiring harness plugs into the Door Module
The Door Modules wiring harness, which is likely called a wiring pigtail, passes through the door, then into the trucks cab.
I believe that in the Cab, where you would rest your Left Foot, that Kick panel hides an Electrical Connector, i think the wires there, pass through trucks Firewall.
So IF my assumptions are correct, you would need to find a Wiring Diagram, that explains just what wires are by your Left Foot, behind that Kick Panel
I am assuming ...
That your Ram is a Ram 1500 5th Generation
You may discover for yourself IF it has HEATED Mirrors
Using Capital Letters, enter your VIN into this site
It should have a long list of how it was built, before it was dropped off at the dealership
Check your Tow Mirrors part numbers
double check for yourself
The part numbers for factory option black 2019-2021 manual fold, power adjust, and HEAT are: 68381772AD and 68381773AD
