Side View Mirror Wiring
Andrey Tsytsyn
Vancouver WA
Hey guys, my truck's a 2010 Ram 1500 TRX4. I've recently replaced my side view mirrors with some aftermarket market towing mirrors that have extra wiring for puddle lights and running lights. Trying to figure out where to connect the wires.
I can connect them via the trailer fuses but I'm not sure what each trailer fuses is for based on the manual. Can anyone tell me what each one of these fuses goes to?
J02 30 Amp Pink Bat - Trailer Tow Main
M23 20 Amp Yellow Bat - Trailer Lighting/Pre-Safe #2
M24 20 Amp Yellow Bat - Trailer Tow BUX/HGM
M45 10 Amp Red IGN R-ORC/Trail Tow (BUX) Sense
M46 20 Amp Yellow IGN R-Trail Tow (BUX)
Thanks in advance!
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Thanks in advance!
What set of lights did you use? When I upgrade my 2014 to tow mirrors with turns/puddles it plugged into the factory door module and all that was needed were the features enabled in AlfaOBD
A
Andrey Tsytsyn
Vancouver WA
I got the the Sanooer mirrors. They have the two plugs for the door module and separate set of three wires that in their manual it shows to connect one wire to the trlr right turn fuse, the same wire on the other mirror to the trlr left turn fuse and then a wire from each mirror to the trlr backup lights, the third set of wires goes to the negative post of the battery. Problem is that my fuses aren't labeled that clearly, they have these abbreviations and whatnot that I don't understand.
