Dan Weinel
Hey all. I'm new here. I'm sure the subject matter I'm about to ask about has been asked a thousand times. I'm sorry if this gets repetitive.
I have a 2017 Ram Rebel that has the factory air suspension in it. My truck is going to see quite a bit of time off road and I want to lift it slightly. I'm thinking in the 2.5 to 3.5 inch range. I do an overlanding trip about once a month, so the truck is going to see a lot of dirt.
My first question is, is it even worth keeping the Air Suspension? Or should I just swap it out for coils? If I swap out, what should I be looking at?
My second question is, If I keep the air, how should I go about lifting? Would links and pucks be fine? Or should I not even consider that?
I know I don't even want to considering Rough Country or BDS. I've had horrible luck with those brands in the past. I know I'll need to get UCAs as well. I've done a lot of cheap **** to my trucks in the past and I'm over that at this point. I'm adopting a "buy once, cry once" attitude with this build.
Thank you in advance for your help.
