Hell bent steel.
Scgirardi
So I'm going with hell bent steel level kit. I'd love to Bilsteins but not in my budget. My question is does anyone have the 2.5"? I'm considering getting the 2.5 but scared the truck will look nose high. And my second question is do you have any issues with the 2.5" kit. Most I've heard is vibration when in four wheel drive. I have a 2010 100 4x4. I'm not looking for anyone to give there opinion on Bilsteins so please don't.
Mbrp.Ram
NW Indiana
5.7 Hemi. Mbrp catback, k&n cai
That's what I have
Not nose high at all, pretty damn level
Mbrp.Ram
NW Indiana
As to the noise
Just drove around in four high for three hours pulling cars out of ditches, thank you snow storm decima lol. No noises or vibration that I've noticed. When mds kicks in it may give a little vibration?..
S
Scgirardi
Do happen to know original height measurements?
S
Scgirardi
Also thanks for the feedback. And also what is mds? Having a brain fart
sbarron
Wasilla, Alaska
mDS. Multi-Displacement System. RAM's method of improving mileage by disabling certain cylinders when they aren't needed.
quietpeen
2021 TRX
Hellcat
The only time anybody has any vibration is in 4 wheel drive and under hard acceleration, so under normal driving conditions it never happens. I had 2"hell bent spaces on my 2011 and was happy with them
12sportmc
NC
I have the TGC 2.5 up front and it was definitely nose high, but with the .75 rear spacers installed it sits pretty much level. Issue I had with mine was the upper ball joint popped out. I have since upgraded to Zone Auto UCAs and haven't had any additional issues. On or off the pavement
S
Scgirardi
Did you guys get more height then the product advertised?
quietpeen
2021 TRX
Hellcat
I unfortunately never measured
12sportmc
NC
Did you guys get more height then the product advertised?[/
If I recall correctly, i got exactly 2.5" out of mine. I wrote it down, I'll dig around for it tomorrow and let you know
S
Scgirardi
That would be awesome. Thank you sir.
12sportmc
NC
2.5 exactly. Went from 36.5 to 39" from the ground to the center point on the fender above the tire.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Curious how much cheaper is this method then Bilsteins. It can't be too much savings.
quietpeen
2021 TRX
Hellcat
Around $100 or a little more cheaper
S
Scgirardi
I got the spacers for 50 bucks on black Friday including a promo coupon code. The cheapest I'm finding the Bilsteins are around 115.00 a piece.
S
Scgirardi
180 dollar savings is worth a chance in my opinion. Some people are die hard Bilstein and act like nothing else is acceptable nor will work.
Mitag3
Eastern Nebraska
2014 Ram 1500 Express
I'm assuming 2.5" of height change isn't enough to be an issue but when going a spacer route and maintaining the stock shocks/springs do you notice a difference in ride since you're changing what part of the shock/spring you're using? For instance when I had my Jeep I had to get longer travel shocks because I would run out of travel when a wheel articulated down.
12sportmc
NC
You can get a kit with the front and rear spacers from Top Gun Customs for 130. I caution you on the 2,5 though again, seems to be the magic height the stock upper control arms don't like. I rolled the dice and ended up having to buy the Zone UCAs for the better ball joints. Complete set of bils for the front and back is 330. Actually cheaper than the spacers once you add in the cost of replacement UCAs. As far as ride quality, I didn't notice anything better or worse when I put mine on, seems to ride the same.
Orca
