Hello everone i have a 2003 dodge ram 5.7 2500 high beam issues
ramit47
Monroe
im having head light issues low beam works fine but when i turn high beam on both high beam lights are super dim an my lamp out light comes on has anyone had this problem is how did you fix it I'm thinking ground issue
jws123
nj
Stock head lights and bulbs? not led correct?
Dean2
Near Edmonton
Check the voltage and resistance on the high beam circuitIt. Make sure you have 12 volts when HB is on. It is also likely your ground wires are in need of cleanup. Go through all of them and your dim light will likely be cured. check the voltage and resistance on the high beeam circuit
