HELP!!! Can the P0344 code be tied to MDS issues?
Andersonracing87
NH
Here is the story… I live in the northeast driving a 2014 2500 with 6.4l (105,000 miles) and about a week and a half ago got a CEL and Traction light and my 6.4 started to do some new tricks. It would run ok at steady throttle at roughly 2000 rpm but anything below it would surge and anything above it would fall on its face. I pulled over and checked the code and found P0344. I was able to clear it and re-fired the motor and it ran fine. I picked up a new cam sensor and replaced it the next day. Fast forward a day or two and I get the same issue and symptoms. Again, reset and move on with no trouble. Replaced the connector for the cam sensor in hopes that a bad wire or connection may have been my culprit. No luck. The problem resurfaced. The other item I have noticed in the mean time is that when the MDS kicks in, I can here a noise that sounds like an electrical coil cycling rapidly. After the last time the code came up, I shut off the MDS and have only driven with it off and have not had the code come up again. Any thoughts on why or how these two could be tied together or is it coincidence? Thanks
