help level 2500
Sticks2010
Central, NJ
Hey guys new here. I need to level the front end for plowing. Few questions, what's the best/ cheapest way to do so? What is needed? Thanks for help.
bloombloom88
Plano, Texas
2wd or 4wd? If 4wd most guys use bilstein 5100s to level their trucks.
2wd just use coil spring spacers, 5100s do not fit as far as I know
Stangshcky12
Oshkosh, WI
5.9 Cummins
5100s don't level 2500
A good cheap option would be a 2" leveling spacer from hell bent steel or top gin customs sells spacers from 1" in .5" increments
New extended shocks would be a good idea, I wouldn't raise the front end anymore then 2" in your case
HEMI1529
2" leveling spacer. Cheap and simple
Wandell
Cummins 6.7
Yep, a 2 or 2.5 inch leveling kit is the cheapest and easiest.
S
Sticks2010
Central, NJ
Thanks guys. I'm thinking the 2.5" my truck looks to be a good 3+" higher, i don't mind the rake so much just need to pick up the nose. Is anything else needed other then the spacers / shocks? I'm assuming the 5100's would work?
(S.M.R) 101
Corning, NY
2013 Sport
5.7L HEMI
I'm running a 2" ready lift in the front with bilsten 5100's and my truck sits damn near perfectly level.
