HELP! New Alternator still not charging on my 97 1500
ramtough1963
LAS VEGAS, NEVADA
I replaced my alternator on my Truck, it still shows below 11 volts on the gauge and kills the Battery. New alternator tested good, new cable ends. I remove the positive cable and she dies. Its the larger amp unit even though I don't have any electric goodies except side mirrors and A/C. The truck can set for days or weeks and the battery doesn't drain down only when it runs. I'm at my wits end
Mop
Sounds like a short somewhere. If you can't find the short, or if you don't want to go through the hassle, the best thing might be to get a 1-wire alternator. Eliminate the system completely.
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
when did the problem start? how long has it been there? check all fuses and relays? more than likely a wire rubbing somewhere, check those grounds and make sure cables are clean connecting to terminals.
