Help! Ticking after lifter and camshaft replacement.
EdGs
FL
Sorry, I'm not sure.
Like I said, mine had the chipped valve stem and other wear. I ordered new pushrods and valve springs just because of my mileage
I replaced the valves and rockers because of the wear on the end of the arm that contacts the valve spring.
I suppose you could measure the pushrod lengths and see how worn down they are, and also check that the oil hole on them is not peened smaller.
I think the rocker arms ran about $150 each at RockAuto, all the valves was another $600 I think. Plus I hand lapped them as well.
I really hated to drop the coin I did, and I may have replaced some stuff I didnt have to, but I didn't want to have to go back in again.
There is a really long thread about my cam and lifter journey:
EdGs
FL
@BillNye, did you soak your new lifters, and did you bleed them before you installed them?
Some on here have said new lifters take a bit to quiet down.
Did you have any engine codes after your cam job?
EdGs
FL
B
BillNye
New Orleans
I did not. Was under the impression they were already soaked from the factory since they were oiled up already.
New Jersey, United States
5.7L Hemi V8
178k miles. Replaced all lifters, shaft, and oil pump with all mopar parts. Install went smooth, but as soon as I cranked it, it starts ticking. I gave it about 10-15 minutes of running and it still hasn’t gone away. Motor runs a little rough also so I just shut it off. Going to take the valve covers off tomorrow to see. Any other advice? Attached a video of the tick.
Sounds like a Hemi, must be a Hemi!
EdGs
FL
There are differing opiniins on this
B
BillNye
New Orleans
image.jpgPulled the plugs because I didn’t do it before. Gonna be replacing them and cranking it up again as soon as I get everything together.
EdGs
FL
Sorry, was driving and couldn't comment. Some soak their new lifters (I did), some don't.
There's a video from MMX about bleeding the lifters before install (I did this as well).
He does say not to soak the lifters, but I did (for a couple weeks, lol). I did the bleeding before I installed them into the block.
Even though this vid just shows non-MDS lifters, I did ALL of my lifters, MDS and non-MDS.
I had no tick at startup.
EdGs
FL
I didn’t see anything wrong. I just put everything back exactly as I did the first time. The #1 plugs were pretty fouled out though.
Well, that's interesting.
Have heard sometimes new lifters are noisy for a good bit, but mine were quiet. I also presoaked, and bled them. Who knows?.
Glad you got it sorted out.
Dusty
Rochester, New York
Did you prime the lifters with oil before installation?
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 148370 miles.
Hardracer
Swfl
2010 1500 laramie 4x4 crew cab
I've read and asked questions about the pre- soaking....same deal,some say you don't need to,they fill up up pretty fast.
We've run into that here on the dyno,kind of a noisy ticking(these are gm engines)..after a couple starts things quiet down...but until then your like what did I do wrong?
My view on that is ...what's it gonna hurt if I want to soak them anyway?
I'm always gonna pre-soak myself.
mdc1990zr1
Conshohocken, PA
I bet you pre fill your oil filter too!!!!
Sorry, just couldn't resist
ramathorn4000
calif
My bud had lifters replaced 2 or 3 times in a row by dealership under warranty loaner truck too. Heads once still had the tick. He started lemon law stuff. They bought him out with cash and a new motor not to lemon law it. So he did that and sold. It. Came out ahead money wise but took his time and the pleasure of new truck he thought would be trouble free. If he wanted to work on a truck, he has approximately 6 project trucks from rock crawlers drag cars desert trucks show cars etc.
moates49
